How to expose FME Feature Attributes with the SQLExecutor?
  • Jan 27, 2020 3:39 PM UTC
  • 5 replies
  • 504 views
Hello,
I'm having troubles with exposing FME Feature Attributes with the SQLExecutor.
I use the SQL Executor with this statement:
And therefore I entered these attributes to be exposed:
I would like to add the FME Feature Attribute ‘SAMPLE_NR’.
- How do I need to add the attribute to the SQL statement?
- And what should I put as ‘Attribute to Expose’?
I tried this:
With the term SAMPLE_NR or '' or as Attribute to Expose. But each time I get the value <missing> in the SAMPLE_NR column.
Thanks in advance for any help.
  • Jan 27, 2020 3:47 PM UTC
Basically you cannot expose a dynamic attribute since they're not known until the workspace is executed.
You will find a lot of posts on this subject here in the forums.
For solutions, look up dynamic schema, this is a great starting point: https://knowledge.safe.com/articles/1050/dynamic-workflow-tutorial-introduction.html
oscard
Forum|alt.badge.img+23
  • Jan 27, 2020 4:39 PM UTC
If I understand your problem, you need to add the Initiator attributes to the Result attributes.
Try changing this paramter of the SQLExecutor:
Forum|alt.badge.img+54
  • Jan 27, 2020 5:02 PM UTC
Have you tried altering the SQL to, presuming you just want the value used in the query to be populated in an attribute called SAMPLE_NR
'@Value(SAMPLE_NR)' as SAMPLE_NR
  • Jan 28, 2020 8:39 AM UTC
This indeed does the job, thank you!
  • Jan 28, 2020 8:44 AM UTC
This also works if one wants all the FME Feature Attributes to be exposed by the SQLExecutor (instead of only one of them).
I wasn't aware of the use of this parameter, thank you!
