How to exclude creating intersection point of cross lines ?
  • Aug 17, 2023 6:31 PM UTC
  • 66 views
spiderman
Forum|alt.badge.img+7
Hello ,
i have used topology builder
Parameter :
end node and intersection , tolerance automatic .
I need it to to let the lines properly noded .
but my problem that it create intersection point for cross lines ,as even „X“ or „T“ .
how could I use topology builder end node and intersection and avoid effect on cross lines ?
my target : to let the line properly noded then count the no. of overlaps point on line .
I have used topology builder end node only ,it does not create intersection point but my network need to clean so I have to clean the data first .what should I do ?
FME 2021
thanks in advance .
daveatsafe
Forum|alt.badge.img+24
  • Aug 18, 2023 8:53 PM UTC
Hi @spiderman​,
Could you draw a diagram of the type of cleaning you need to do on the lines, if you do not want the crossing intersected? That might help us figure out a solution.
