How to download zip file using httpCaller
  • Nov 6, 2017 4:53 PM UTC
  • 666 views
danilo_fme
Forum|alt.badge.img+58
  • Nov 6, 2017 5:06 PM UTC
Hi @jurate2911,
1) Transformer Creator
2) HttpCaller:
Request_URL: your link with .zip
HTTP Method: GET
Response = Save Response Body to : File
Output FileName: your folder
Thanks,
Danilo
  • Dec 15, 2017 4:07 PM UTC
Thank you so much for your help.
I have built my transformer but now how do I plug that in. To what should I connect transformer to and to what I should connect output to?
danilo_fme
  • Dec 15, 2017 6:10 PM UTC
Hi @jurate2911, Could you share your Workspace?
  • Dec 16, 2017 4:49 AM UTC
If you just want to download a zip file from a web server, only the workflow suggested by @danilo_fme (i.e. Creator and HTTPCaller connected in series) is enough to accomplish the goal. If necessary, you can also connect some other transformers to the Output and/or <Rejected> port of the HTTPCaller, in order to log the downloading result.
Have you succeeded downloading a zip file with @danilo_fme's method?
