How to dissolve polygons only if there isn't an obstruction
  • Aug 5, 2018 1:01 AM UTC
  • 28 views
I have a set of touching polygons representing physical spaces and lines representing the doors on the polygon boundaries dividing the spaces. I want to dissolve only the polygons that aren't separated by a door. Not sure how to group the corresponding shapes. The doors are only a small segment of the boundary.
  • Aug 5, 2018 6:28 AM UTC
Could you please share a sample dataset including spaces (polygons) and doors (lines)?
