how to detect overlapping polygons in a single dataset
  • Aug 7, 2024 11:47 AM UTC
  • 109 views
esther_gift
Participant
Forum|alt.badge.img+7
Which transformer can I use to identify overlapping polygons in a single dataset and show them as the output.
tomfriedl
Forum|alt.badge.img+14
  • Aug 7, 2024 12:35 PM UTC
You can use the AreaOnAreaOverlayer.
liamfez
Forum|alt.badge.img+44
  • Aug 7, 2024 12:37 PM UTC
You could try the AreaOnAreaOverlayer and then a TestFilter to separate out the features that you want afterwards.
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/areaonareaoverlayer.htm
liamfez
  • Aug 7, 2024 12:41 PM UTC
Whoops sorry, your post had not loaded when I typed mine, did not mean to double up the answer.
