How to detect feature value with only white space
  • October 10, 2019
  • 102 views
lazarlubomir
Forum|alt.badge.img+7
Hello everybody,
I just have one tricky issue - how can FME detect attribute value, which is composed strictly by white spaces, e.g. ? Its not empty value in DB view, but it is hardly detected. Any idea please?
It doesnt matter on count of white spaces.
Thank You so much!
Lubo
Best answer by sigtill
Use a StringSearcher, select the attribute and the following parameters. Then you will have a list called _allWhitespaces with all the whitespaces together. So if the attribute has 3 whitespaces the list will consist of 3 elements
Forum|alt.badge.img+39
  • October 10, 2019
A string searcher with some regex?
^\s+$
sigtill
Forum|alt.badge.img+24
  • October 10, 2019
lazarlubomir
  • October 10, 2019
@egomm @sigtill, how simple, I have tried to find it in difficult way...
Thank You os much!
