How to create wkt column from coordinates of LineString ? (generic solution for shape type)
  • Dec 22, 2021 12:29 PM UTC
  • 252 views
coordinates of given type
lineeextract coordinates and type
resim_2021-12-22_153824
danilo_fme
Forum|alt.badge.img+58
  • Dec 22, 2021 12:48 PM UTC
Hi @ikubra800
Did you try to use the stringsearch?
Do you want to separate lat and long, correct?
Thanks in Advance,
Danilo
geomancer
Forum|alt.badge.img+71
  • Dec 22, 2021 4:58 PM UTC
Your attribute coordinates reads like:
[x1,y1][x2,y2][x3,y3][x4,y4]
WKT for a linestring has the following format:
LINESTRING (x1 y1, x2 y2, x3 y3, x4 y4)
So perform a bit of consecutive search-and-replace:
  1. Replace ',' (comma) with ' ' (space)
  2. Replace '][' with ', ' (comma space)
  3. Replace '[' with 'LINESTRING ('
  4. Replace ']' with ')'
Search_Replace_to_WKT
  • Dec 23, 2021 3:00 PM UTC
Thanks for response @danilo_fme​  and @geomancer​ ,
I solved that GeoJSON (Geographic JavaScript Object Notation) reader directly.
danilo_fme
  • Dec 25, 2021 12:36 PM UTC
Hi @ikubra800​
Thanks your feedback. It is a very good that you solved the problem with the GeoJSON Reader.
