How to create key:value pair in JSON from fme_attrib_info{}.field_name and fme_attrib_info{}.field_value?
  • Aug 14, 2020 10:23 PM UTC
  • 165 views
jspratt
I have attempted a few different techniques to get my desired output.
1.) Reader->AttributeExposer->JSONTemplater
2.) Reader->AttributeExposer->ListConcatenator->JSONTemplater
3.) Reader->AttributeExposer->JSON Writer
4.) Reader->AttributeExposer->ListKeyValuePairExtractor->
5.) Reader->AttributeExposer->ListExploder->JSONTemplater
6.) Others
I am working with values such as:
objid | fme_attrib_info{}.field_name | fme_attrib_info{}.field_value |
1       | SERIAL_NUM                       |          12345                          |
2       | TYPE                                     |          SOME_TYPE              |
My desired output would be as follows:
    "SERIAL_NUM": "123456",
    "TYPE": "SOMETYPE
I've used the tutorial on site here for extracting attributes from CAD blocks. Now, I would like to take these attributes and make a json payload per unique block to be written to a database. How might I go about doing something like that?
Thanks!
Best answer by takashi
Hi @jspratt​ , a possible way is to use the ListExploder and the JSONTemplater with a sub expression.
Root expression:
{| fme:process-features("SUB") |}
SUB expression:
{fme:get-attribute("field_name") : fme:get-attribute("field_value")}
listexploder_jsontemplater
Alternatively you can get the same result using just a single JSONTemplater with this Root expression. In this case, you don't need to use the ListExploder.
    let $values := fme:get-list-attribute('fme_attrib_info{}.field_value')
    for $name at $i in fme:get-list-attribute('fme_attrib_info{}.field_name')
    return {$name : $values[$i]}
  • Aug 15, 2020 7:30 AM UTC
Root expression:
SUB expression:
