How to create an attribute from a JSON response?
  • Jan 29, 2021 10:50 PM UTC
  • 907 views
rev1I'm reverse geocoding (XY coordinates to addresses) and I'm getting some business names back instead of the actual address. The data I need is in the full JSON response, but I don't know how to access this information.
After looking closer into the JSON results I found that the address I'm given is a short hand version of the data. I want the _arcgis_longlabel, instead of the _address field. How can I extract this specific attribute from the json response?
rev2
chrisatsafe
Hi @zemken12​ ,
Have a look at the JSONExtractor transformer. You can extract portions of JSON into attributes using this transformer. If you're new to working with JSON in FME, I'd highly recommend taking a look over the getting started with JSON in FME article as it will cover everything you'll need (and likely more).
  • Feb 25, 2021 3:52 PM UTC
Hi @zemken12​ ,
Chris - Thanks for the info. I was able to extract the specific fields from the JSON response by using the JSONFlattener. Under 'Attributes to Expose' I added the attributes of interest eg - '_latitude' or 'flat_address.City'. Hope this helps someone in the future. Thank you.
