How to create a new value whenever I come across a threshold in sorted data?
  • Jun 6, 2023 9:37 AM UTC
  • 81 views
wrijs
Forum|alt.badge.img+5
Hello,
I have a dataset that looks similar to the image shown and I need to create the value in the attribute ROUTE shown in red. image.pngI need to create a new value for ROUTE whenever Duration>1 or Duration is Null.
The data needs to be sorted firstly by Name, then by TimeStamp.
Then, whenever the previously mentioned condition of (Duration>1 or Duration is Null) is met, a new value needs to be created for ROUTE.
How do I create a new value (with for example a new sequential number) whenever I come across (Duration>1 or Duration is Null) in my sorted data?
Best answer by geomancer
Use the Adjacent Feature Attributes option of the AttributeManager to have access to the attributes of the previous feature, and provide your logic as a Conditional Value.
Routenumber(Note: I added some extra logic where Name B begins. This may not be needed.)
geomancer
Forum|alt.badge.img+71
  • Jun 7, 2023 7:40 AM UTC
wrijs
  • Jun 12, 2023 1:16 PM UTC
That did the trick, thank you
