How to correct the error shown below?
  • Jul 11, 2022 12:08 PM UTC
  • 22 views
@malavikavenu96​ Translation Failed is usually an FME crash so you may need to contact your local FME supplier for additional assistance. But based on the previous message it looks like it might be caused by Scripted Parameter . So the first step might be to remove the scripted parameter and see if the workspace runs OK.
If you need to contact your local FME provider, include details about the version of FME, a copy of your workspace (saved as a workspace template if possible) and any other details that migtt help
