How to convert this to run in FME to pass all excel file types .xlsx out to an attribute. What I want to achieve is to recurse into every folder on my list, recursing into subfolders to identify all .xlsx files and return their file paths.
  • August 24, 2023
  • 16 replies
  • 158 views
fme
Forum|alt.badge.img+7
import os
def get_excel_file_paths(folder_path):
  excel_file_paths = []
  for root, dirs, files in os.walk(folder_path):
    for file in files:
      if file.endswith(".xlsx"):
        excel_file_paths.append(os.path.join(root, file))
  return excel_file_paths
folder_path = "/path/to/my/folder" ----I have a list of folders in a csv file which i read into the workspace so i plan to use that attribute here
excel_paths = get_excel_file_paths(folder_path)
for path in excel_paths:
  print(path)
Having troubles converting this to run in fme
Thanks!
Forum|alt.badge.img+51
  • August 24, 2023
A Directory and File Pathnames reader would be the FME way to achieve this
boydfme
Forum|alt.badge.img+10
  • August 24, 2023
Basic Single Implementation
You can use a path reader to read in a single folder location:
path reader
And then just set the text search for excels (*.xlsx) and say yes to look in subfolders:
imageWhen setup you will get attributes for all the file paths and other ancillary information as attributes. This would satisfy looking into 1 folder location with subfolders (if present).
For a recursive approach using your csv:
You could read in the csv and whatever attribute contains the folder directories you need to search (with subfolders) for excels you could link that to a FeatureReader transformer and then populate the settings as above as a PATH reader. To make it dynamic you would just use your csv attributes to populate the base folder path in the FeatureReader settings.
So each "feature" from the csv will enter the FeatureReader and populate the base folder directory where it should look and then find all the .xlsx's.
fme
  • August 24, 2023
@ebygomm​ could you please share the workspace in the screenshot? Trying it out now but the feature reader does not seem to give me the ports in your screenshot and also failed.
I did not think the featurereader had directory and filepath readers in it so was looking at more of a python implementation as it needs to go through lots of folders to retrieve the file paths. However, I will try this out and monitor its efficiency. Thanks
fme
  • August 24, 2023
path reader
@boydfme​ Thanks for your response! It runs but fails in the process. Also, there is no output ports for path_windows etc as it is in using the Directory and File Pathnames by itself.
Forum|alt.badge.img+63
@fme​ you've said, twice, that "it fails". Can you elaborate? Are you getting an error message and if so, which one? How exactly have you set up your workspace?
fme
  • August 24, 2023
@Hans van der Maarel​ i've resolved the error. However, after running i don't see port outputs like path_windows, path_unix, etc. (the output ports seen from using the standalone directory and path reader). Do i need to configure something else on the featurereader to see this?
  • August 24, 2023
In the FeatureReader if using the Directory and File Pathnames reader the easiest thing is to set the Output Port to Single Output Port and then choose which attributes to expose. Features with those attributes should then exit the Generic port
fme
  • August 24, 2023
Thanks!@ebygomm​
fme
  • August 24, 2023
@ebygomm​ Can Path reader filter 2 type of files? Eg. a pdf and xlsx instead of using different path readers?
boydfme
  • August 24, 2023
yes. For example:
*.{pdf,xlsx}
fme
  • August 24, 2023
@boydfme​  Thanks you! Appreciate the help!
fme
  • August 29, 2023
Is there a way to implement batch processing in fme workbench? The path reader is currently taking days to go through the folders to retrieve the files. Is there a varied efficient way to do this?
  • August 29, 2023
I've seen reports previously of poor performance with the path reader when recurse is set to yes
Perhaps you could see if a python solution is any quicker?
import fme
import fmeobjects
import glob
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self, feature):
        root_dir = feature.getAttribute('directory')
        for filename in glob.iglob(root_dir + '/**/*.xlsx', recursive=True):
            feature.setAttribute("filename",filename)
            self.pyoutput(feature)
    def close(self):
        pass
fme
  • August 30, 2023
import fme
import fmeobjects
import glob
    def __init__(self):
        pass
    def close(self):
        pass
Thank you @ebygomm​  I got an error after replacing directory with path windows from path reader reading folder names. Attached is a screenshot of the error. Thanks for all the help!
  • August 30, 2023
import fme
import fmeobjects
import glob
    def __init__(self):
        pass
    def close(self):
        pass
You've duplicated feature.getAttribute when changing the name in the line starting root_dir
fme
  • August 31, 2023
import fme
import fmeobjects
import glob
    def __init__(self):
        pass
    def close(self):
        pass
Thank you @ebygomm​  I am currently using workspace runner to go through all the files within the folders to be processed. However, I noticed something strange as in when I set Workspace run per Fme process to 1 with Maximum Concurrent FME processes set to 7, I have more records in my output than when i increase that number. It looks like there is data loss when Workspace run per Fme process  is greater. With a low number, it takes hours to process the files and wished it would work with Workspace run per Fme process set to 1000 or more. Is this a bug with Workspace Runner or am I missing something?
