How to convert surface (like LandXML) to IFC?
  • Mar 18, 2020 7:33 PM UTC
  • 538 views
I would like to convert surface data (like mesh or LandXML) to IFC (using for example the ifcTriangulatedFaceSet class). I think, it has to be quite easy but I have no idea how to write those IFC data.
I attache an input example-file (LandXML).
Thank you very much for any suggestions.
Franco
  • Nov 28, 2022 10:56 AM UTC
Could be quite easy achieved with XSL stylesheet.
Example which could be expanded to create result in IFC:
monitotier
  • Jul 18, 2024 1:15 PM UTC
Can someone post a step by step to run a process where GML are transformed to IFC?
THANK YOU!
ali-safe
Forum|alt.badge.img+24
  • Jul 22, 2024 8:04 PM UTC
Hi, @monitotier.
There is a tutorial that covers IFC to GML. Might get some ideas from there. If you are still stuck, happy to help find if its possible.
Thanks,
