How to convert polygons to lines and vice versa?
  • Feb 12, 2014 8:11 AM UTC
  • 6 replies
  • 3932 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out how the conversions are implemented in the FME. For example, how polygons are converted to polylines and vice versa?
Thank you
Best
Jamal
Forum|alt.badge.img+63
There's the GeometryCoercer which can turn a polygon into a closed polyline. Then, depending on what you want and what your data looks like, you can use an Intersector and/or a Chopper to remove overlapping lines and cut them up into smaller bits.
fmelizard
Forum|alt.badge.img+22
  • Feb 12, 2014 9:52 AM UTC
And the area builder correctly grouped to return to polygons
gio
Forum|alt.badge.img+15
  • Feb 14, 2014 3:48 PM UTC
dont forget to treat donuts seperatly...
jamal
  • Feb 14, 2014 7:58 PM UTC
Many thanks for the help. It works fine
Best
Jamal
thewindgone
  • Jun 26, 2020 7:47 AM UTC
Hi, I have a similar question. I turn a polygon to a closed polyline with GeometryCoercer, and then try to decompose it to four lines. But instead of four lines, the result is many of broken segments with Chopper, or only one closed polyline with Intersector. Why is that? Can you help me? Thank you so much.
Forum|alt.badge.img+54
  • Jun 26, 2020 8:21 AM UTC
Probably better to post this as a new question
