How to convert DWF to DWG with all layers ?
  • Nov 13, 2017 3:29 PM UTC
  • 159 views
After converting the DWF to a DWG file, all layers were meshed into one. Also hatches are completely different from the original - hatches converted into singular lines. Is there any way through the Transformer Gallery sets to convert it to the most similar possible version and with all layer names?
Thank you!!
andreaatsafe
Forum|alt.badge.img+17
Hi @inesgulbenkian,
Are you able to share your workspace or via a support case?
Have you set the "Layer Name" parameter for the writer feature types? https://www.screencast.com/t/OW9uc7wxzS
