How to Convert ArcGIS Projection to FME
Hello
Does anyone have any idea on how can i convert ArcGIS projection to FME.
pratap
Forum|alt.badge.img+12
  • May 9, 2016
Use EsriReprojector transformer to use the ESRI projection. If you want to add custom projection then just save the projection to Favorites and use from that location.
Pratap
  • May 10, 2016
Pratap
Thank You Very much pratap i will try your suggestion. and let you know of the results.=)
