How to convert a timestamp?
  • September 15, 2017
  • 571 views
I 'am reading a Json file that contains a timestamp. I need to convert this to a date so that I can aggregate other data on Year, Month.
I've tried using an attributemananger (@value/86400)+25569+(-5/24) and DatConverter to convert the timestamp but this didn't gave me any results.
Therefore my question how to do this?
Best answer by redgeographics
If it's the seconds since the Unix epoch you can use the DateTimeConvertor. Source format is %s, output format can be FME or ISO date, whichever you prefer.
What is the format of the timestamp in your json? It would be helpful if you could post an example here.
  • September 18, 2017
This is an example of a timestamp. "lastUpdated":1502349196
But additional: In my attributemanager I am using the Arithmetic editor. This results in a number.
Do I have to do something to convert this back to a string? I thought I read something that FME automatically convert this when needed.
Forum|alt.badge.img+50
Ok, I feel a bit stupid now. I've read the help but it didn't came up to me that I could change the Source Date Format. This works (of course)! Thanks.
