How to convert a point to polygon
  • Aug 23, 2022 12:33 PM UTC
  • 7 replies
  • 504 views
joe.fme
Hi all, I have a couple of point features which are feeding through with polygons (as the points should join to polygons, bar these 2). I've tried the GeometryCoercer and CenterPointReplacer etc but no luck. Is there something I'm missing which could create even a small polygon from a point?
dustin
Forum|alt.badge.img+36
  • Aug 23, 2022 12:49 PM UTC
You could use the Bufferer, which will create a circle polygon around each point.
joe.fme
  • Aug 23, 2022 12:51 PM UTC
Good idea! Will try. Thanks
joe.fme
  • Aug 23, 2022 1:02 PM UTC
Update - I seem to get both of them rejected with these values
dustin
  • Aug 23, 2022 1:03 PM UTC
Could you share your log file?
joe.fme
  • Aug 23, 2022 1:08 PM UTC
I can't really due to the folder and feature names, but with the bufferer bit, it returns this. No errors etc, just to rejected -
2022-08-23 14:05:39|  0.3| 0.0|STATS |Bufferer_BUFFERED Feature Counter -1 2147614888 (TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2022-08-23 14:05:39|  0.3| 0.0|STATS |Bufferer_<REJECTED> Feature Counter -1 2147680424 (TeeFactory): Cloned 2 input feature(s) into 0 output feature(s)
2022-08-23 14:05:39|  0.3| 0.0|STATS |Destination Feature Type Routing Correlator (RoutingFactory): Tested 0 input feature(s), wrote 0 output feature(s): 0 matched merge filters, 0 were routed to output, 0 could not be routed.
dustin
  • Aug 23, 2022 1:13 PM UTC
Are your points 2d? According to the documentation the rejected port is for non-2d features. If you want the translation to continue regardless of the rejected features, you can change the parameter in the screenshot below to Continue Translation. Sometimes you can glean more information about the rejection if you let the translation continue through.image
joe.fme
  • Aug 23, 2022 1:17 PM UTC
It does continue on rejected features - appreciate the help though, seeming to struggle with the simplest of bits!
Edit - had a change round and chose "ground units". Got it working! Thank you
