How to convert 3D CAD solids to shapefile
  • May 8, 2018 2:41 PM UTC
  • 196 views
I'm new to FME and I need to convert a 3D as-built model in CAD format to shapefile. The as-built model contain 3D solids representing pipelines and cylinders. Any help pointing me to the right direction would be greatly appreciated.
fmelizard
Forum|alt.badge.img+22
  • May 8, 2018 6:28 PM UTC
Hi @olivarrer - there are a few good Cad/Bim to GIS webinars available which should help. Also at the bottom I've linked one which talks about working with 3D in FME. I would start with the first two. I think they will be the most applicable to you here.
https://www.safe.com/webinars/bim-and-gis-integration/
https://www.safe.com/webinars/how-to-create-gis-and-bim-interoperability/
https://www.safe.com/webinars/how-to-exchange-data-between-cad-and-gis/
https://www.safe.com/webinars/exchanging-data-between-cad-and-gis-systems-with-fme/
https://www.safe.com/webinars/how-to-transform-data-between-autocad-and-gis/
Here's one which focuses on 3D which has some good info: https://www.safe.com/webinars/3d-fme/
  • May 8, 2018 11:53 PM UTC
Hi @MattAtSafe, I appreciate these. I'll go through these and hopefully I'll find what I was looking for.
Thanks!
