How to configure pythoncaller to dissolve with arcpy?
  • December 21, 2016
  • 101 views
Hey!
Can someone help me to set up a python script in Pythoncaller.
I don´t konw how to define the outport so the workspace can continue with the dissolved data.
I have tried this without result..:
def processFeature(feature):
arcpy.Dissolve_management(feature, Output_Feature_Class, "feature.getAttribute('mergeid')", "", "MULTI_PART", "DISSOLVE_LINES")
I need to use the arcmap dissolver because the FME dissolver makes some polygons disapear with my big dataset!
  • December 21, 2016
You have to first write out the feature class in FME, execute arcpy and then re-read the feature class back into FME. You could accomplish this by chaining several workspaces.
You cannot use the PythonCaller as if it were a transformer with arcpy, unfortunately.
jdh
Forum|alt.badge.img+41
  • December 21, 2016
I have successfully used featureWriter -> PythonCaller with Arcpy -> featureReader, no chaining of workspaces necessary.
  • December 21, 2016
Ok. Thanks for the answer.
  • December 21, 2016
Ah, yes, the FeatureWriter might be an option, I agree.
