How to compare two lists and output different elements?
  • November 20, 2019
  • 7 replies
  • 645 views
bobo
Forum|alt.badge.img+3
I've got two identical line/point features, each of them has a list of all attributes created by Aggregator. I want to compare these two list, some elements are same and some are not and number of elements may not be same. Matcher or ChangeDetector can do comparing part but can not out which elements are different. Is there a way to compare two lists and output different elements? Or can I just compare attributes of two features without creating lists?
sigtill
Forum|alt.badge.img+24
  • November 20, 2019
Perhaps use the ListBasedFeatureMerger ?
bobo
  • November 20, 2019
I read the help document and I don't think it is what I wanted, maybe you can show me an example?
Forum|alt.badge.img+39
  • November 20, 2019
Presumably you want to avoid having to explode the lists?
bobo
  • November 20, 2019
I can live with that, and the list was created based on the attribute.
  • November 20, 2019
Do you want to compare the attributes of each feature, or the attribute values of each feature? Or both?
I think a changedetector might be able to help you here. As it will provide a list of the differences
bobo
  • November 20, 2019
Attribute values of each feature mainly, if the attributes between two feature are not same, then just skip the comparing part and just output a message in a newly created attribute.
verdoodtdries
Forum|alt.badge.img+19
Assuming you have two lists where the only difference is the number of elements. In that situation one can detect the additional elements using Python.
# Get  FME-list into a Python-list
myList1 = feature.getAttribute('myList1{}')
myList2 = feature.getAttribute('myList2{}')
# Cast list to set
# Substract set
# Cast to list again
myDifference  = list(set(myList2) - set(myList1))
Note that it is possible to convert your FME-list into a Python-list.
