How to compare two json without looking the order of their attribute?
  • Jun 30, 2017 11:19 PM UTC
  • 168 views
arthy
Forum|alt.badge.img+8
I have two json and I would like to test if they are equal without knowing their attribute name? How can I automatize it using either a transformer or python caller?
_result= [{"attributes":{"OBJECTID":objectid, "ATTRIBUTE1": A1 ,  "ATTRIBUTE2": A2 ,  "ATTRIBUTE3": A3,"ATTRIBUTE4": A4, ... ,"ATTRIBUTEN": AN}}]
_result if the generic syntax of my json document.
Thanks
@takashi
  • Jul 1, 2017 3:11 AM UTC
Hi @arthy, assuming the feature has two JSON documents as its attributes called "_result1" and "_result2", a PythonCaller with this script determines if the two JSON documents are equal on both property names and values, and then saves the result ("yes" or "no") into a new attribute named "_same", for example.
# PythonCaller Script Example [Updated]
import json
def processFeature(feature):
    array1 = json.loads(feature.getAttribute('_result1'))
    array2 = json.loads(feature.getAttribute('_result2'))
    feature.setAttribute('_same', 'yes' if (array1 == array2) else 'no')
  • Jul 1, 2017 3:20 AM UTC
import json
updated the script example.
arthy
  • Jul 4, 2017 3:37 PM UTC
import json
@takashi,
Thank you very much.
I really appreciated.
It worked.
