How to compare roads attributes in two cities?
  • Dec 30, 2020 4:14 PM UTC
  • 6 replies
  • 91 views
bobo
Forum|alt.badge.img+3
Hi, everyone, I have road data of 2 cities, roads at their boarder may have same attributes like name, width and lane and I want to know if their attributes are the same. If there's only 1 road on each side, it's easy by using list. But like the figure below, if there're more than 1 road on each side, I can't find a way to build the right list. Maybe road A in city 1 and road D in city 2 are same road, or road A in city 1 and road C in city 2 are same road, so I want to build two lists with road attributes( road A and C, road A and D). No matter I use PointOnLineOverlayer or Intersector, I can only build a list with all roads attributes in it. Road A, B ,C ,D intersect at same point on the boarder.
Can anyone help me out? I want to build 4 lists, A and C, A and D, B and C, B and D
无标题
@bobo​ Can you attach a small sample dataset? Someone might create an example workspace for you.
What you need to do is process the lists you've created. Have a look at the many list processing transformers available in FME. If those don't quite work ten you might need to revert to PythonCaller - see the very end of the article above for a small example of using Python with FME lists
bobo
  • Jan 5, 2021 11:00 AM UTC
Hi @Mark Stoakes​ , I've upload a sample dataset. I want to put the attributes of each two roads on both sides in the same list, then I can compare if their attributes are the same. May I can use Intersector to get the intersect point and then PointOnLineOverlayer to create the list. For example, road A and road C in list 1, road A and road D in list 2. But now I can only get road A, B, C, D in same list.
You can use a NeighborFinder it looks like. To compare both sides, add a 2nd NeightborFinder with the inputs switched and that should give you all possible combinations.
Workbench
neighborsTable
table
@bobo​ Thanks for including the data. NeighborFinder will work as suggested by @jlbaker2779​ . You could add a Group By: Name so only the same roads match.
Or use the SpatialRelator, something like this:
workspaceexample workspace attached (FME 2020.2)
bobo
  • Jan 6, 2021 4:26 PM UTC
Thanks Mark, but sometimes each name of the intersected roads may not be the, I mean that there're​ maybe four names for four roads, then group by may not work as expected.
@bobo​  In that case drop the group by and add a ListExploder. That will give you every pair.
