How to compare attributes come from 2 feature list
  • Oct 1, 2018 2:33 PM UTC
  • 39 views
After use some transformer: PointOnAreaOverlayer and NeighbourFinder, I have 2 feature list with a attribute Name.
Then I need to combine these 2 feature:
- If Name in list 2 already exist in list 1 then set it = 0
- If not then do no change.
So please help me: which transformer I can use to compare 2 feature list?
I try with Tester but don't know how to look up in the all array.
And Matcher will merge the 2 feature which I don't want.
Thanks,
jdh
Forum|alt.badge.img+41
  • Oct 1, 2018 4:12 PM UTC
Simplest way would probably be to unconditionally merge the list2 (requestor) and list1 feature (supplier) feature, explode list 2 (ListExploder), ListSearcher (List1, name), on the found port Name = 0 (attributeCreator), ListCombiner to rebuild list2.
