How to combine the values from two datasets based on range comparison?
  • Sep 15, 2023 11:06 AM UTC
  • 70 views
tb09114
Forum|alt.badge.img+28
I have two datasets, where one (a) is holding x/y/z coordinates and the other (b) contains a distance value.
I created a line, based on the coordinates from dataset a, and after densifying the line used a measure to get values I can compare to the distance values provided by dataset b.
The distance and measure values are not perfect matches, and I would like to accumulate the attributes from dataset b to dataset a based on an a rule like the following:
IF 'ref_length' >= 'start_length' AND 'ref_length' < 'end_length'
This is what I have so far
workflow
churchfraser
Forum|alt.badge.img+5
  • Sep 28, 2023 11:38 PM UTC
You may have solved this already, but I will attach a potential workflow for any future users who come across this.
I would suggest:
  • Joining all the feature ranges from Dataset B onto Dataset A using a FeatureMerger
    • Set Process Duplicate Suppliers = Yes
    • Set Generate list = Yes
    • Set List Name = 'attribute_list'
    • Set Add to List = All Attributes
  • Exploding the list of relationships using ListExploder
    • List Attribute = attribute_list{}
  • Testing the resulting relationships 'ref_length' >= 'start_length' AND 'ref_length' < 'end_length'
    • You could use In Range instead
imageIt's not the most efficient process, because the number of relationships will equal (Dataset A count)*(Dataset B count) which can get large quickly.
Alternatively, you could use an InlineQuerier with a custom SQL statement with the following configuration:
imagewhere the SQL Query is
SELECT Dataset_A.*, Dataset_B.*
FROM Dataset_A CROSS JOIN Dataset_B
WHERE Dataset_A.ref_length >= Dataset_B.start_length AND Dataset_A.ref_length < Dataset_B.end_length;
