How to combine LeftRightSpatialCalculator and NeighborFinder
  • Jan 24, 2018 4:20 PM UTC
  • 88 views
Hi guys,
I have 02 shapefiles (point and line), I want to find the nearest line for each point [relation 1 (line) to many (point)] inside a diameter of 15m and to find the relative position of those points.
Thanks for help
Best answer by takashi
Hi @messaoud2010net, if I understand the requirement correctly, this workflow might help you. Assuming that "ID_TRC" is an attribute which can be used to identify each line uniquely.
  • Jan 25, 2018 8:47 AM UTC
M. takashi You're so helpful
james.c
Forum|alt.badge.img+3
  • Sep 6, 2019 4:32 PM UTC
@takashi
Hi Takashi
I seem to receive an 'INVALID_BASE_GEOMETRY_TYPE' rejected error when I set my workbench as specified. Would you know what is causing this error please?
Thanks
James
nampreetatsafe
Forum|alt.badge.img+14
@takashi
Hi Takashi
Thanks
James
Response provided here: https://knowledge.safe.com/questions/98254/leftrightspatialcalculator-produces-and-invalid-ba.html
