How to change the MPolygon Fill color in DWGStyler transformer
  • Jan 31, 2018 10:42 AM UTC
  • 119 views
Hi @erik_jan, @ciarab
Is there any option in DWGStyler Transformer to change the MPolygon fill color?, I've the ROUTE feature which is displaying the right color HTML: #c0c0c0 .
I need the 'MPolygon with fill pattern' color to be displayed the same HTML: #c0c0c0, currently i'm selecting the 'Fill Pattern name' as solid and the output of it is displayed as shown in the attached snapshot (Outer boundary as color #c0c0c0 and inner polygon filled with black. Is there a way i could change the inner polygon color to the same as outer boundary color-#c0c0c0.
Any help would be appreciated.
Regards, Anil.
Best answer by fmelizard
Hi @anilkb1105,
I think here you may need to use a FeatureColourSetter after the DWGStyler. It does look like there is a limitation with the DWGstyler here. I tested the FeatureColorSetter and the fill color was picked up by the DWG writer. Attached is an example.
mpolygonwithfill.fmw
fmelizard
Forum|alt.badge.img+22
  • Jan 31, 2018 4:48 PM UTC
Hi @anilkb1105,
  • Feb 1, 2018 10:29 AM UTC
Thank you @MattAtSafe, its working fine after adding the FeatureColourSetter transformer to the DWGStyler output. Is there a possibility of addressing this limitation in DWGStlyer transformer itself.
Thank you for your help here.
