How to change a temp location on FME server Express installation and a seperate engine
  • Jan 20, 2020 3:50 PM UTC
  • 75 views
jsmitsman
What I want: changing temp location on the server with the FME Server express installation.
Last week, I installed FME server "express installation" on windows server and added a seperate engine also on a windows server.
I added on both servers an FME_TEMP environment variable with a reference to another "temp disk", and restarted all the services on both servers. The seperate engine machine is writing the temp files verry well to this location, but the server with the "express installation" not. What can I do more to changing the temp location for this machine?
  • Jan 20, 2020 3:54 PM UTC
It should work on both servers, regardless. On the server that doesn't behave as expected, make sure that
jsmitsman
  • Jan 21, 2020 7:55 AM UTC
Hi david_r,
Thanks for your answer. This problem is solved now by changing the Log On account from local System account to a specified user account of the Engine services. Thanks for your help!
