How to call list elements when the list is a parameter in a custom transformer?
  • Nov 20, 2020 10:51 PM UTC
  • 120 views
dhaulagiri
Forum|alt.badge.img+4
I want to create a custom transformer that concatenates the elements of a list entered as a parameter. This list is like: elements {0}, elements {1}, elements {2}... elements{x} and contains words. The start index is also an input parameter. As the number of items in the list varies, I created a loop where I get the index of each item.
My problem: my list $(_ list) is a parameter and I don't know how to call its elements to add them to the string I want to build.
Can you help me?
Nicolas
danilo_fme
Forum|alt.badge.img+58
  • Nov 22, 2020 3:25 PM UTC
Hi @dhaulagiri​
I think the transformer ListConcatenator can be helpful for you.
Did you try to use it?
Thanks in Advance,
Danilo
dhaulagiri
  • Nov 22, 2020 7:49 PM UTC
Thank you @danilo_fme​
I looked at this transformer but I think it necessarily concatenates all the elements of a list. I must choose the starting index, because depending on the results of the previous treatments, I have to keep all or delete the first, the first two or the first three elements...
danilo_fme
  • Nov 23, 2020 1:19 PM UTC
Hi @dhaulagiri​
Thanks your feedback.
The custom transformer ListSlicer can be help for you.
It's possible to start a index and after create a string ( concatenated process ).
I published the parameter for start index and used before the transformer ListElementCounter ( to get the number of list element generated ).
ListSlicerAttached the Workspace.
Thanks in Advance,
Danilo
dhaulagiri
  • Nov 25, 2020 7:40 PM UTC
 Thanks @danilo_fme​ , this is exactly what I need! I hadn't seen this transformer at all.
But if this solution solves my problem, it doesn't answer my question: I would like to know how to refer to an element of a list passed as a parameter. It might help me one day or another. Anyone know?
