How to calculate average azimuth of lines in sets of 1-3 lines.
  • Sep 6, 2021 6:41 AM UTC
  • 233 views
My situation is this. I have a number of lines in a gdp on top of which I have some points (with a unique id called nodename). I want to rotate these points based on the angle of the lines. What I have done so far to achieve this is to make a buffer around the points, clip the lines using the buffer. Use the horizontalanglecalculator to calculate the azimuth of the lines. However some points have 3 lines coming through them meaning I have 3 angles for 1 point. I need to calculate the average of the x number of angles for each nodename.
Can anyone help me with this? See the picture below.
Udklip
Regards Rasmus
Best answer by nielsgerrits
  • Assign unique ID's to points called point_id using a UUIDGenerator.
  • Merge attributes when clipping, so the lines get the point_id attribute.
  • Clipped lines to StatisticsCalculator, calculate average, group by point_id, summary outputport.
Now you have one feature for each point with the average of the angle.
nielsgerrits
Forum|alt.badge.img+67
  • Sep 6, 2021 7:13 AM UTC
That solved the problem perfectly. Thank you very much!
