How to add Photos to a KMZ Archive File?
  • May 12, 2022 6:57 PM UTC
  • 210 views
u12runm
Forum|alt.badge.img+4
I am trying to covert geotagged photos from a mobile phone and convert them into a KMZ file, every works great except the actual photos are not being inserted into the KMZ file... How do I fix this?
debbiatsafe
Forum|alt.badge.img+24
Also answering here in case it helps other users.
To add files referenced in the description HTML, the Additional Files option in the KMLPropertySetter should be enabled and the Source File and Path in Dataset parameters should contain valid values. This sets the format attributes kml_additional_files{}.href and kml_additional_files{}.path on the feature.
