How to add more than different numbers for specific user parameters in translation parameters
  • Nov 4, 2021 8:12 AM UTC
  • 90 views
gogopotter90
Forum|alt.badge.img+14
i would like to write different numbers for input parameters 2354 or 6985 or 4893
i mean ,i want to add different input numbers and inside the workspace i have added test filter for the input user parameters
if specific attribute has 2354 or 6985 or 4893 should do function .
so my question : how could i add input parameters more than id numbers
FME 2018 ,thanks in advancetranslation parameters
Best answer by panda
Not sure if this is how you want it. But i'm assuming 2018 FME would have "Choice" option in the User Parameter. (Right Click User Parameter to get other option to pop up) You could put value listing above into it.choiceI'm also on FME 2021 so it will look slightly different, but i think the right hand box should look similar to FME 2018.
choice_paramPNG
panda
Forum|alt.badge.img+20
  • Nov 4, 2021 2:20 PM UTC
choice_paramPNG
gogopotter90
  • Nov 4, 2021 2:43 PM UTC
Thanks @panda for ur reply
