How to add gml:id to a CityGML Polygon element
When writing CityGML, gml:ID is added to the surface feature (WallSurface, RoofSurface, GroundSurface) however, there is no ID written to the polygon of the surface. How can i create an attribute to set the gml:id of the polygon of the surface feature?
Thanks,
Steve
Best answer by takashi
OK. In your case, you can just use the GeometryPropertySetter with an appropriate Geometry XQuery in order to add the "gml_id" trait to the Polygon part.
GeometryPropertySetter: Geometry XQuery | Test Clauses
Part to TestLeft ValueOperatorRight ValueThis partGeometry Type=IFMEPolygon
Assuming that the input surface feature has an attribute called "gml_id" that stores the Polygon ID value (e.g. "id_19_205_polygon"), the parameters setting looks like this.
If the Polygon part always has the geometry name "exterior" (and other parts don't have the same name), this test clause would also be available.
Part to TestLeft ValueOperatorRight ValueThis partGeometry Name=exterior
The most suitable Geometry XQuery setting could be vary depending on the conditions and the requirements.
Hope this helps.
mark2atsafe
Forum|alt.badge.img+44
  • August 31, 2017
Hi @steveway
I think you'd need to use an AttributeCreator to create an ID attribute called gml_id. Follow up with a GeometryPropertySetter to set these as traits using the attribute you just created as the source.
I'm not a 3D expert but I'm fairly certain that is the right way to go about this. If not, let us know and I'll investigate some more.
  • August 31, 2017
Hi Mark, I am doing that to create the cityGML surface feature, but that feature will have a multi surface element which then has a polygon element. It is this polygon element to which I want to assign a Gml:id. I believe what I am looking for is very similar to this post: https://knowledge.safe.com/questions/3695/setting-gmlid-attribute-to-geometry-in-citygml.html
Kind regards,
Steve
  • August 31, 2017
Hi Takeshi,
Here is a screengrab to illustrate the geometry class, and structure (which is valid CityGML):
Here is an example of what I am getting:
<bldg:RoofSurface gml:id="id_19_205">
<bldg:lod2MultiSurface>
 <gml:MultiSurface srsName="EPSG:27700" srsDimension="3">
  <gml:surfaceMember>
   <gml:Polygon>
   </gml:Polygon>
  </gml:surfaceMember>
 </gml:MultiSurface>
</bldg:lod2MultiSurface>
</bldg:RoofSurface>
And Here is an example of what i require:
  <gml:surfaceMember>
   <gml:Polygon gml:id="id_19_205_polygon">
   </gml:Polygon>
 </gml:MultiSurface>
</bldg:RoofSurface>
Thanks,
Steve
  • September 1, 2017
Hope this helps.
  • September 1, 2017
Hope this helps.
Thank you Takashi, worked a treat!
