How do I transfer measure values from points to lines?
  • Nov 3, 2023 9:14 PM UTC
  • 150 views
matthewb
Forum|alt.badge.img+12
I have polyline data representing roads and point data representing mile markers. The points are on the line, so PointOnLineOverlayer does segment the line as expected. The point data has a Measure value that I want to use on the line, how do I set the measure value of the points to the lines?
daveatsafe
Forum|alt.badge.img+24
  • Nov 3, 2023 9:57 PM UTC
Hi @Matthew Boyter​,
The FME Hub transformer MeasureCalibrator will transfer the point vertices and measures to the line for you.
matthewb
  • Nov 6, 2023 2:32 PM UTC
Hi Dave,
Thanks for the reply. I was testing the MeasureCalibrator before asking the question and was getting lines through that weren't being assigned measures, even though they have points with measures on them. The red polyline is the RejectedLines output on the Measure Calibrator and the blue dot is the MeasureChecker=True output. Approximately 15% of the polylines with point features with measures are being rejected from the MeasureCalibrator. FME_MeasureCalibrator
daveatsafe
  • Nov 6, 2023 4:43 PM UTC
Hi Dave,
Are you able to share the problem lines and points? You can scrub all the attribute information - I just need the geometry to run through the MeasureCalibrator to see why the measures aren't transferring.
matthewb
  • Nov 7, 2023 8:39 PM UTC
Hi Dave,
Unfortunately not. I was able to able to resolve the issue by increasing the distance in the MeasureCalibrator to well over the needed distance though.
