How do I sort a list of features by an attribute value in a PythonCaller?
  • Oct 31, 2023 11:49 AM UTC
  • 236 views
dms2
Forum|alt.badge.img+11
I'm working with groups of features and I want minimize the number of blocking transformers in my workflow. Right now I'm using a Sorter to sort features in each group and a PythonCaller to make some attribute manipulation and comparison. Both transformers block the flow so  I wanted to get rid of the Sorter and do the feature sorting inside the PythonCaller but I don't see how to do it.
Once I have the list of features, what should I do to sort them by one or any number of attributes?
Thank you!
import fme
import fmeobjects
class FeatureProcessor(object):
    def __init__(self):
        self.feature_list = []
    def input(self, feature):
        self.feature_list.append(feature)
    def close(self):
        pass
    def process_group(self):
        for feature in self.feature_list:
Best answer by david_r
Have a look at the tutorial here: https://www.geeksforgeeks.org/sort-a-list-of-objects-by-multiple-attributes-in-python/
You'll want to skip the "for" loop on line 16 and pass self.feature_list directly to the sort() function.
  • Oct 31, 2023 1:09 PM UTC
