How do I set the import path in FME's Python interpreter?
  • August 2, 2017
  • 9 replies
  • 408 views
I have a module . in a folder (called '/wscloud/email_automation/wsa/lib')
I can import it if I append the path explicitly, but this seems like a very clumsy way to do this. Is there a way I can configure the import path in settings?
Thanks,
Fuad.
import fmeobjects
import sys
sys.path.append('/wscloud/email_automation/wsa/lib') #ew!
import wsa
Best answer by carsonlam
Instead of modifying sys.path, paths can also be specified in the PYTHONPATH environment variable.
carsonlam
Forum|alt.badge.img+7
  • August 2, 2017
  • August 2, 2017
Ah, thanks! Do you know how/where I do this on a Mac (macOS Sierra) so the change is permanent?
carsonlam
  • August 2, 2017
I think you can modify ~/.bash_profile and add 'export PYTHONPATH=foo'.
  • August 2, 2017
I did that and it works if I run python in Terminal
>>> import wsa
>>> import sys
>>> print sys.path
['', '/wscloud/email_automation/wsa/lib', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/Sy...
but it still fails to import in FME
My command-line python path is very different from the one FME gives me if I print sys.path from each.
I think that successfully initialized bash, but not FME (but I'm out of my depth here)
carsonlam
  • August 2, 2017
>>> import wsa
>>> import sys
>>> print sys.path
After modifying .bash_profile, you may need to restart your machine for the change to fully take hold.
  • August 2, 2017
I shutdown and restarted but I have the same problem - Python in Terminal is good, but FME python does not know about PYTHONPATH :(
carsonlam
  • August 2, 2017
I asked around, and unfortunately it turns out Macs behave differently here, and Workbench won't pick up environment variables this way. You might have to stick with doing it the ugly way. You can also try putting the Python module and its dependenciesin the same directory as the FME workspace, if that's possible in your use case.
  • August 2, 2017
Thanks for digging in - as a recovering PC guy and now Mac guy, usually things go the other way! I will try a sym link and if that fails, and an actual copy as fallback.
  • August 3, 2017
Yup - putting a sym link to the include path in the folder that contains the workspace solves this. Thanks Carson!!!
