How do I set noData on a raster output?
  • January 14, 2014
  • 105 views
fmelizard
Forum|alt.badge.img+22
I have a 3 band GeoTIFF. All i want to do is convert it to JP2 and ECW formats. This works fine, except that the noData isn't set. I want a value of "255" to be noData.
I've tried using the RasterBandNoDataSetter, and then I tried putting a RasterBandNodataRemover in front of it, and then I tried putting a RasterSelector in front of that, but all to no effect.
I don't want to change the data in any way, just flag that 255 is noData.
This seems like it should be simple; what am I doing wrong?
Thanks,
Jonathan
fmelizard
  • January 14, 2014
fmelizard
  • January 14, 2014
Hi Itay,
Thanks. Is this an FME specific thing or a format thing?
I can use ArcGIS to create a JP2 file that has noData. Unfortunately it can't export ECW so I can't test that.
Cheers,
Jonathan
fmelizard
  • January 14, 2014
Hi Jonathan,
A format thing, could be that the 'nodata' in ESRi is an internal thing too.
Itay
