How do i keep input file name while using the Attribute Transposer?
  • Feb 3, 2021 8:36 PM UTC
  • 91 views
My goal is to batch deploy the process to many CSV.
The transposer is only keeping the attributesof the table. FME_basename and all other attributes are dropped.
With one file at a time i'm able to link to the source data set. but its not working when i batch deploy. It's keeping the same name and my files are overwriting each other.
Thank you for your help
Best answer by redgeographics
If you're only running one file at a time you can use a FeatureMerger to merge the attributes of one original feature (through a Sampler) unconditionally with the output of the AttribtueTransposer, like this:
Screenshot 2021-02-04 at 09.09.30
Forum|alt.badge.img+63
  • Feb 5, 2021 3:11 PM UTC
Thank you! it worked!!!!!
