How do i convert AutoCAD block attributes from a name and value list to an attribute table?
  • Jan 23, 2018 3:03 PM UTC
  • 114 views
I am trying to create an attribute table using name values exposed from an autoCAD block and assigning this modifiedtable the associated attribute values.
At this point in time i am unable to transpose this data
Example 1:
I have attached the workspace and drawing file to assist anyone who can help
Workspace:
Drawing file:
Best answer by mark_f
When you add the Reader there are different parameters for managing the entities. I just had a quick test and changed to Attribute Schema. This seems to expose the attributes you're looking for to the Workspace. You might need to add the Reader again.
  • Jan 23, 2018 6:15 PM UTC
