How do I convert a date such as 12/31/1979 to Julian date in FME?
  • Oct 26, 2021 10:20 PM UTC
  • 141 views
chrisatsafe
Should be able to do this with the DateTimeConverter.
Set the Input format to:
%m/%d/%Y
And the output format to:
%y%j
2021-10-26_16-21-22More Date/Time Functions and explanations here if needed.
Hope that helps.
  • Nov 1, 2021 7:42 PM UTC
%m/%d/%Y
%y%j
Hope that helps.
Thanks chrisatsafe. A follow up question, how can I extract a four digit year instead of two?
  • Nov 1, 2021 7:47 PM UTC
Ignore the follow up question. I figured it out, I use uppercase "Y" instead of lowercase "y". Thanks a lot for your help.
