How do I configure compression support for TIFF format?
  • Aug 15, 2023 1:58 AM UTC
  • 299 views
rclarkenz
I am trying to read a GeoTIFF that has LERC compression.
I created a workbench in FME 2021 that read and mosaiced some GeoTIFFs with LERC compression and wrote them to GeoTIFFs with LZW compression. I was able to do that successfully.
However I'm trying to do the same thing now in FME Workbench 2023.0 with the same files and I'm getting the following errors:
2023-08-15 13:18:41|   0.1|  0.0|INFORM|GEOTIFF reader: Opening file 'C:\Temp\DEMs\CB11_10000_0502.tiff'
2023-08-15 13:18:41|   0.1|  0.0|WARN  |GEOTIFF reader: C:\Temp\DEMs\CB11_10000_0502.tiff: C:\Temp\DEMs\CB11_10000_0502.tiff:LERC compression support is not configured
2023-08-15 13:18:41|   0.1|  0.0|ERROR |GEOTIFF reader: C:\Temp\DEMs\CB11_10000_0502.tiff: Cannot open TIFF file due to missing codec.
2023-08-15 13:18:41|   0.1|  0.0|ERROR |GEOTIFF reader: Failed to open the dataset 'C:\Temp\DEMs\CB11_10000_0502.tiff'. Please ensure source data is valid and correct reader is selected
2023-08-15 13:18:41|   0.1|  0.0|WARN  |GEOTIFF reader: An error has occurred. Check the logfile above for details
How do I configure compression support?
evieatsafe
Forum|alt.badge.img+28
  • Aug 16, 2023 5:31 PM UTC
Hi @rclarkenz​ unfortunately this sounds like a bug. Could you submit a support case with us with your log file and workspace(s) 2021 vs 2023 and we can take an in depth investigation. Thanks!
