How do I check the current Implicit Datum Shift Configuration on FME Server?
  • March 9, 2017
  • 31 views
fmelizard
Forum|alt.badge.img+22
I want to know if FME Server has a Datum Shift Configuration set. How can I check?
https://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Configuring-Datum-Shifts.htm
rylanatsafe
Forum|alt.badge.img+14
Run the following command as an Administrator:
<FMEServerDir>Server/fme/fme LIST_SETTINGS CoordSys
