How do I acces projectwise directly through the feature reader ?
  • Sep 20, 2022 1:37 PM UTC
  • 232 views
jonathanklarup
The usage notes in ProjectWiseWSGConnector states:
  • The FeatureReader can access ProjectWise directly (without using the ProjectWiseWSGConnector), however, a local copy of the dataset will not be created.
But how is this done?
Thanks in advance.
Best answer by david_r
Here's how:
imageNotice that the "Format" setting in the FeatureReader refers to the format of the file you're reading out of ProjectWise.
  • Sep 20, 2022 2:14 PM UTC
Here's how:
jonathanklarup
Thank you David, I really dont know how I missed that one.
Is it possible to use a wildcard when reading from ProjectWise?
  • Sep 21, 2022 7:36 AM UTC
If you need to list the contents in a ProjectWise folder, you could try with a FeatureReader using the Directory and File Pathnames reader:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/path/path.htm
At some point I suspect it might be better to simply use the ProjectWiseWSGConnector, however.
jonathanklarup
Thank you, I'll try it.
