how create an offset for polyline with different distance (start and end)
  • November 28, 2017
  • 103 views
I'd like to do an offset for polylines (left or right) with starting distance d1 and ending distance d2). is-there a simple way to do that (affiner with some explication please or another method))
thanks.
  • November 28, 2017
Hi @miladahmad, this workflow might help you. The TaperLineBufferer is a custom transformer from FME Hub.
  • November 28, 2017
thanks. I'm doing that but if I have d1= 0, I got only one polyline. Then I do intersector and LeftRightSpatialCalculator to get only right or left. Is-it a little complicated or what I'm doing is correct?
Actually, I have roads centerline and I’m trying to have a polygonal roads network (when road have 2 lanes, I need to have 2 polygons (the right one is sometime different from the left one). I need to have also the left and right outline of polygon (see image).
You helped me in this question https://knowledge.safe.com/questions/56751/taper-buffer-from-left-or-right-side-of-line.html
And this one https://knowledge.safe.com/questions/58526/how-to-create-fillet-between-2-polylines.html
Is what I’m doing is correct or I’m using a complicated method?
thanks agin.
