How could I write output always by arcsde writer if no content
  • Nov 14, 2023 3:37 AM UTC
  • 43 views
gogopotter90
Forum|alt.badge.img+14
Hello ,
Could I create tables (Feature classes ) in Arcmap by using Arcsde writer even if there is no content ( empty content )
my problem : I have to export the data required monthly from Fme .
sometimes ,no data output .
sometimes there are new data .
in case no data ,i would like to have always feature class , when I show the table of content in arcmap ,I see it is empty .
even if there is output or not ,i would like to have monthly feature class has the same name . How could I achieve it ?
fme 2021
itsmatt
Forum|alt.badge.img+48
  • Nov 14, 2023 1:34 PM UTC
You can put a NoFeatureTester into your workspace - this will create a feature if no features come into it. You could pass this feature to your SDE table - it would still create a record though so maybe not really what you're after?
hkingsbury
Forum|alt.badge.img+73
  • Nov 14, 2023 7:25 PM UTC
If you're looking to make an empty FeatureClass, you'll need to use ArcPy (this can be used in a PythonCaller in FME)
https://pro.arcgis.com/en/pro-app/3.0/tool-reference/data-management/create-feature-class.htm
gogopotter90
  • Nov 17, 2023 7:07 AM UTC
Thanks but how could I write the script in Python caller and let it work .
sorry Iam not so familiar with Python .
could you provide me a temperate workspace include the script Python caller ,thanks a lot in advance
fme 2021
gogopotter90
  • Nov 17, 2023 7:08 AM UTC
Thanks for ur reply .
i got ur idea ,it is good if I did not solve it with Python caller ,so I can use it .
