How could I specify attribute in FME regarding to domain then writing output in Esri arcsde ?
  • Nov 1, 2023 4:26 AM UTC
  • 109 views
soly
Forum|alt.badge.img+3
Hello
I need help .
i would like to write the output from Fme in Esri arcsde
but this sde has already domain called Base
this domain include 2 coded value ,yes or not .
i would like to ask ,how could I specify specific attribute in FME regarding to this domain .
then when I work with this table in arcmap later ,the user get choose list (yes or no ) at this attribute (column ) .
another question to get more knowledge , could I create domains for arcsde in Fme ,will be possible ?
i hope if I find the answer .
thanks in advance
FME 2021
nielsgerrits
Forum|alt.badge.img+67
soly
  • Nov 1, 2023 12:48 PM UTC
Thanks for reply .
but if I do the same at arcsde writer ,so when i show the data output in arcmap .
will the attribute contain choose list (yes or no ) as I wish ?
