How could I fill a hole in a polyon?
  • January 24, 2017
  • 308 views
I need to simply fill a hole in a polygon geometry. Is there a transformer to dissolve the geometry somehow?
Best answer by itay
You can use the DonutHoleExtractor to separate the holes from the outershell.
Hope this helps.
itay
Forum|alt.badge.img+17
  • January 24, 2017
Hope this helps.
  • January 24, 2017
Hi @robertdbuckley, the DonutHoleExtractor transformer migh help you.
  • January 24, 2017
oops, got 10 seconds later than you, @itay :-)
jpvo
Participant
  • Participant
  • January 24, 2017
Hope this helps.
Alternatively, if you're interested, you can filter holes against a desired area and rebuild your geometry with only the holes that you're interested in:
  1. DonutHoleFilter
  2. DonutHoleExtractor
  3. DonutBuilder
.JP
