how could i extract the map after using clipper and add to the sheet file .
  • Mar 18, 2020 1:07 PM UTC
  • 76 views
gogopotter90
Forum|alt.badge.img+14
i would like to ask :
is it possible , to extract the map after using clipper and add to the sheet file .
the output that i get n inspector ,i would like to let workspace to save the map automatic new sheet file in my feature writer .
Thanks for help
danilo_fme
Forum|alt.badge.img+58
  • Mar 18, 2020 11:08 PM UTC
Hi @gogopotter90
Could you be give more details?
Did you write the Map using FeatureWriter?
Thanks,
Danilo
gogopotter90
  • Mar 19, 2020 8:29 AM UTC
Hi @gogopotter90
Thanks,
Danilo
i mean, after i used clipper and i check on the inspector how it looks like .i would like to add one excel sheet has the photo of map
beside another sheets that it includes attributes by feature writer ,i need also to have the photo of output in seperated sheet.how could I do that .
Thanks for any help
