How can you set a raster file name before it enters the Feature Writer?
  • Jun 16, 2021 1:44 PM UTC
  • 80 views
I have a workspace that generates multiple GeoTiffs that have feature attributes that I use for naming the files in Feature Writer.
e.g. ...2021-06-16_9-39-06I want to modify the workspace and change the FeatureWriter to write the images to KML/KMZ.
When I change the FeatureWriter to write KML I lose the ability to name the images. Is there a way to name the images before the enter the FeatureWriter?
hkingsbury
Forum|alt.badge.img+73
  • Jun 16, 2021 11:41 PM UTC
for the KML writer, you'll need to enable "Fanout Dataset" in the writer parameters (in the navigator panel)
Screenshot 2021-06-17 114031
The above has the same results only using the KML Writer instead of using the FeatureWriter Transformer.
The TIFF files are still named sequentially <name>_1.tif, <name>_2.tif, etc.
When the FeatureWriter is set to output TIFF the files can be named using the Feature Attributes. I want to be able to keep these filenames inside the KML/KMZ file.
