How can I write "fme_aggregate" to "autocad_region"
  • Jul 13, 2018 9:54 AM UTC
  • 53 views
I am trying to convert a .shp to a .dwg (RealDWG) file. I was able to successfully write all "fme_donut" to "autocad_region", however all my attempts to write "fme_aggregate" (multi-patch polygons) to "autocad_region" were unsuccessful. This is my understanding that FME can handle autocad_region by subtraction (donut) but not by addition (multi-patch). I am wondering if you have any solution to do the job.
Many thanks
Regards,
Hani
jneujens
  • Jul 13, 2018 12:27 PM UTC
And it is absolutely necessary that you use multi-patch polygons?
The only thing you can try (as far as I know) is to set the correct settings in the DWGStyler transformer.
